Hi, I have been trying to have create code block in dynamo that takes 2 inputs (evaluates input 1 to see if it is greater than 8 or not; if greater than 8 then I want the software to apply a certain formula…if not want to do something else). But I seem to been having difficulty having the function run…it give me a null response…could you please help…please see below:
def FunctionName (input1,input2)
S=(input1>8? 1.5*(input1-8)(input2)+(8input2):input1*input2);
return=s;
r=FunctionName(11,2);
There are a number of problems:
You can’t use a ternary operator in associative DesignScript blocks. You need to declare a Imperative block instead. This applies to any if statement
Ternary operators currently don’t work in Imperative definitions anyway, the bug has been reported on Dynamo GitHub, so you need to use an if statement block instead
You have typo’s. ‘s’ and ‘S’ are two different objects
More typo’s: input2 and 8input2
missing a binary operator here (i assume you meant to multiply hence the typo of ‘8’?): (input1-8)(input2)
Check out the Dynamo DesignScript intro here
Thanks Thomas it was very helpful and solved the bug!!! I appreciate the help.
