Hello Gems,
I am trying to use logical statement in imperial code block, but it doesn’t works for lists, instead it does well with single Integer / double.
Kindly have a look at an example:
Can anyone help in figuring this out?
Thanks,
Regards,
Wajed
When you make ‘x’ variable = list, the statement x > y no longer works.
You’re not comparing an integer > integer, instead you’re comparing list > integer which doesn’t work.
You have to iterate over a list using “for”
I’m not sure if you can use “for” in imperative blocks though?..I’d look at a python node for this
If I convert ‘y’ and ‘z’ to list, then too the result is same.
just have a look:
again, if you’re comparing lists you’ll have to iterate over them with a ‘for’ function.
you can’t compare them with a basic operand like > or <
The same thing doesn’t work for python node too:
If I convert ‘y’ & ‘z’ in list then too.
Can you please guide me with an example?
It worked. Thanks @andy.leong
Here’s the code successfully done.
