i’m currently searching for a way to get the same sheet order from revit in my excel sheet. I can get the sheets from revit in excel except the order that i want. Hope someone can help me.
in many ways,the idea is how to find a common key between two lists, if you export the excel previously from revit, export the Element ID value with it.
if it is manually created, use sheet number for example, sort the both list by alphabetic, it should be the same
