Re-arrange sheet elements on a list based on sheet number
hi there
i am trying to assign a numbering list to my sheets so it will show in schedule.
the problem is that whenever you create a new sheet and you place it between existing sheets, the id of the sheet will not fit correctly in the list, and the numbering order will be incorrect as a result.
is there a way to make the list be sorted by sheet number instead of the sheet id ?
HI @adiga55555
you can use SortByKeys node , use the sheets as a list, and sheet number as keys
thanks
exactly what i needed
:sunny:
