How do I add my own study in Refinery version 0.62.2?
This is necessary to make a study for Parking Layout (see attached screencast) ?
- Export for Generative Design fails
- Create study
- You can only choose 3 samples studies.
- How do I add study types ? -> didn’t work
https://autode.sk/2Ura5cO
Thanks in advance.
You need to clean up your output nodes so the graph exports. Do this by modifying your graph to ensure the following:
- All outputs are single items, not lists.
- All outputs are numbers (doubles or integers).
- All outputs return a value, not a
null when run.
You should then be able to use the graph as a study type.
@jacob.small
I don’t quite understand what you mean.
The Dynamo file have been added. Can you possibly indicate an example where things go wrong?
Thanks in advance.
Parking Layout Optimization_2.dyn (1.7 MB)
@jacob.small
In this post you will find the download link to the Dataset.
RVT file -> Parking Layout
DYN file -> Parking Layout Optimization_2
https://we.tl/t-odbHTP3IxM
