How can I use Dynamo to add a column to an existing Revit schedule?
I’ve never used dynamo before but this is something that will save hours on editing a current project. Any help is appreciated. Below will be images of what I’m attempting to add in. The clips vary for some sheets.
I’ve never used dynamo before but this is something that will save hours on editing a current project. Any help is appreciated. Below will be images of what I’m attempting to add in. The clips vary for some sheets. 122
122222
Welcome to the forums.
What have you tried so far? If you’re new to Dynamo I suggest you take a look at the Dynamo Primer and work your way through it. Also, try searching the forum for similar topics before asking your question. There are many posts that already cover this topic.
There are a few options here.
I would create a new Shared Project Parameter assigned to the Panel Category
That way it keeps your options open, with that you can do with what you have in the schedule, you can also have in a tag.
Make sure to set it as an instance parameter.
I appreciate your response.
Thank you.
