How can I install Surface.Difference?
I saw other people using (Surface.Difference) but I can not find it in my Dynamo. Thanks in advance.
What Revit and Dynamo version are you on?
Hello, thanks for your response. I’m using Revit 2020 and Dynamo Revit 2.1.0.7733.
Think it first comes with revit 2020.2 think its Dynamo 2.3 so if you are on previous version you dont see it :wink: you will need to upgrade, but there are other nodes there will do the job as well
Yes. It is the quickest solution for this issue. Thank you for your response. I updated it and I got that command.
