How Can I get start and end point using python
I am working on some python codes.
And I have some problem Could you please explain that how can I get start end point from curve.
Hi @eness.gun
retrieving start and end point is easy. You can use many ways to achieve it.
You’ll want to be a bit careful of single items versus list items :slight_smile:
import sys
#Input variable of "Lines"
lines = IN[0]
#First we check if the item coming in is not already a list. We make it one if it is not.
if not isinstance(lines, list):
    lines = [lines]
#Creating an empty container to put our results in
results = []
#Here we check each element (Line) inside the list (Lines)
for line in lines:
    #If there is one element, we treat it a different way to multiple
    if len(lines) > 1:
        #We append the results to our empty "results" container
        results.append([line.StartPoint, line.EndPoint])
        results.append(line.StartPoint)
        results.append(line.EndPoint)
#We return our "results" container out of the Python node back to Dynamo
OUT = results
hello, very educational
thank you
Cordially
christian.stan
