Hi
#Input variable of "Lines"
lines = IN[0]
#First we check if the item coming in is not already a list. We make it one if it is not.
if not isinstance(lines, list):
lines = [lines]
#Creating an empty container to put our results in
results = []
#Here we check each element (Line) inside the list (Lines)
for line in lines:
#If there is one element, we treat it a different way to multiple
if len(lines) > 1:
#We append the results to our empty "results" container
results.append([line.StartPoint, line.EndPoint])
results.append(line.StartPoint)
results.append(line.EndPoint)
#We return our "results" container out of the Python node back to Dynamo
OUT = results
edit:How Can I get start and end point using python - #3 by solamour
cordially
christian.stan
