in some way the python function that i show i picture, will not work.
Is it effected by the list of point and not a point?
Is it a way to make it run in similar way as the boxes above?
Thank you.
Thank you.
you should use looping
for n1,n2 in zip(nod1,nod2):
linje.append(Line.ByStartPointEndPoint(n1,n2))
As @khuzaimah.ElecEng says…
Your code works great for a single set of points…
This would work for either single or list… Someone will tidy my code
from Autodesk.DesignScript.Geometry import Line
point1 = IN[0]
point2 = IN[1]
if isinstance(point1, list):
pointlist1 = point1
pointlist1 = [point1]
if isinstance(point2, list):
pointlist2 = point2
pointlist2 = [point2]
line = []
for p1, p2 in zip(pointlist1,pointlist2):
line.append(Line.ByStartPointEndPoint(p1,p2))
OUT = line
Hope that’s of interest,
Mark
Thanks, helps a lot
