Is it possible to set or get the Height value of a Wall Layer with Dynamo? If yes, how?
You can use Element.MaterialCollector from Universo_BIM package. It gives you area, you can splait area to length, this gives you height.
Thank you for your attention.
This way, If I have a door, the volume may not be related to the height only.
And even if it worked, I could no set the height of the layer.
