How can i follow excel to updated the window & door type mark in dynamo
Hi, i new to dynamo so im I’m confuse on it what I should use to make it happen.
i have a excel file, it have windows type & door type on it, i want to use dynamo to updated it in my rvt project. so i want to ask or can show me what code should i use to make it happen?
thanks for you help.
Hi @Zacz , welcome to the community!
Here are some links you should follow.
How to get help on the Dynamo forums - FAQ - Dynamo (dynamobim.com)
Use Excel import and use set parameter Node. Might help with your task.
ok i try to fix it,thanks
Start the script. if you are stuck somewhere put it here I am happy to help.
Hi,because i new to the dynamo forum cant upload the files so i only can share with you by the screenshot sorry for that.
i try to do a start but im Stuck and don’t know how to continue.
Try from this template
Mark value from Excel.dyn (23.2 KB)
oh ok thanks i try to use that
I’m sorry I didn’t fix the data flow part, can you explain it more or can you show me how to do it?
how do I know-how is your data!
Sorry, I don’t know what dataflow is, I haven’t heard of it before.
This would be you getting the data from your families and/or excel and comparing them. We can’t see the families you’re working with or their parameter/type names so we can’t design that part of the script for you.
This is a common issue on the forums where we can only give guidance when it comes to the context specific portions of a script.
oh ok i got it thanks
