We have a Dynamo Script to extract values for a door type parameter from an excel file and update the door parameter in the model. We use a python node for updating the model. The below script works for the Built in parameter for the the Construction Type parameter. What would I need to change if I were to reference a shared parameter for doors called ‘Frame_Head’?
app = uiapp.Application
clr.AddReference(‘RevitAPI’)
clr.AddReference(‘RevitNodes’)
def tolist(x):
if hasattr(x,‘iter’): return x
else : return
def getIndex(list, item):
i = 0
for s in list:
if s == item:
break
i += 1
return i
doors = tolist(UnwrapElement(IN[0]))
marks = tolist(UnwrapElement(IN[1]))
check =
doorFilter = ListElement
with Transaction(doc) as t:
t.Start("Changing Keynote Value")
for c in doors:
for a in doorFilter:
if Element.Name.GetValue(a) == c:
b = []
b.append(Element.Name.GetValue(a))
b.append(a.get_Parameter(BuiltInParameter.DOOR_CONSTRUCTION_TYPE).AsString())
f = getIndex(doors, Element.Name.GetValue(a))
a.get_Parameter(BuiltInParameter.DOOR_CONSTRUCTION_TYPE).Set(marks[f].ToString())
check.append(b)
t.Commit()
OUT = check
