How can I cut an element using an element from a linked file?
I’ve attempted to create a void using an element from a linked file, but the script doesn’t display any error messages. However, the outcome is false. Can anyone please help me solve this scenario?
Hello and welcome!
3 thoughts, either longest lacing on the past node OR can generic elements even be cut? Not sure without test.
Or does the get from linked file actually copy accross elements or just reference them, cause youd need them to be in your model for this to work.
@pyXam , Thanks for your response. I’ve checked the first two concern of you. those are not a issue for this prblem.
on your 3rd concern,
I tried to copy the element to active document but it showing error.
Something here might help.
Hi @blessy.t something here could probably work as well…if i understand :wink:
Revit_12Lv6yN5hx
@sovitek Thanks dear. Its working…
