How can I create surfaces from polycurves please?
hello, on the following link you have different possibilities with a very detailed example
cordially
christian.stan
A surface through curves is typically known as a loft, of which Dynamo has various means of creating in the base geometry nodes.
Thanks for your answers, but when I have my model lines, I can’t create the surface even using the nodes you mention.
I am getting the error that the curves are not closed, how can I close them automatically please?
We’d need to see your graph and what you’re dealing with. Either you have an open loop or your curves are not sequential. There should be a node for grouping curves to deal with the latter.
Hi @architectepaca …sometimes i am lucky with that one here, but again i dont know if we can see the graph…
Thanks, I’ve made some progress… but I can’t generate this on all the lines at once…
ProjetTEST.rvt (1.8 MB)
