Hi community,
I encountered a problem today that I need to solve, I’ve been thinking about it for hours, and did not find way to get through it.
I am generating via a graph and a rvt file a list of curves that I need to transform into Surfaces. Some curves generated this way have some trouble being converted to surfaces through the Surface.ByPatch node : some of the edges are intersecting each other… Here is a sample of such curves and the expected output (.dyn attached):
test.dyn (9.1 KB)
Does one of you, by any chance, know a node/custom node that might create those surfaces, even though the edges are intersecting (I do not care about the Polycurve itself) ? I don’t care on which type of element that node may work (points, curves…).
I already tested the GroupCurves node from archi-lab, but it is not working on that case
Thanks in advance for your time !
Mustapha
For example, if we added an extra point to the list, it may not work properly.
