Hi all
I’m looking for help with a script I found to export clash results highlighted in a Navisworks clash test into Revit. The script is intended to give clear visual indications of where there are clashes, as detected within Naviswroks, within the Revit file
The idea is that you select a Navisworks file, select the clash tests and results and create a list of instances by element ID. By then having a project parameter called ‘clashes’ within Revit set to a yes/no function and specified for the family categories that correspond with the clash tests.
The Dynamo script should then be able to inform the Revit model which instance has a Clash ‘yes’ instance. By using a view filter the element can then be highlighted with a warning color.
I’m getting far enough with it but there are errors. The ‘Element.SetParameterByName’ node is not returning any values as if no information is getting to it
Any advice would be appreciated.
