View element selected in dynamo
hey i want to know this stupid thing, when i select an element in dynamo and i click the green element id, it zooms in the element, but doesn’t highlight or mark the element which is selected.
is there a node which highlights or marks the element/bounding box/ coordinates in the model?!
Hi @uaftab.cem19 maybe try to get the element using “select by ID” command in revit with the green number or isolate element in view dynano node from clockwork. Cheers
I think @Mostafa_El_Ayoubi did this. Did you mean colouring elements? Been awhile but you could figure it out with custom node probably
clr.AddReference('RevitAPI')
def overridecolor(element, color, fillpatternid, view):
	gSettings = OverrideGraphicSettings()
	gSettings.SetProjectionFillColor(color)
	gSettings.SetProjectionFillPatternId(fillpatternid)
	gSettings.SetCutFillColor(color)
	gSettings.SetCutFillPatternId(fillpatternid)
	view.SetElementOverrides(element.Id, gSettings)
	return element
fillpatterns = FilteredElementCollector(doc).OfClass(FillPatternElement).ToElements()
solidfillid = [f.Id for f in fillpatterns if f.Name == '<Solid fill>'][0]
for j in IN[1]:
	for i in IN[2]:
		if isinstance(IN[0],list):
			color = UnwrapElement(IN[0])
			color = [UnwrapElement(IN[0])]
		adskcolor = [Autodesk.Revit.DB.Color(c.Red, c.Green, c.Blue) for c in color]
		view = UnwrapElement(j)
		elements = UnwrapElement(i)
		for e,c in zip(elements,adskcolor):
			overridecolor(e,c,solidfillid,view)
OUT = elements
Use the SelectInRevit node from spring nodes package to highlight the elements.
Use this python code
def tolist(obj1):
	if hasattr(obj1,'__iter__'): return obj1
	else: return [obj1]
def flatten(x):
    result = []
    for el in x:
        if hasattr(el, "__iter__") and not isinstance(el, basestring):
            result.extend(flatten(el))
            result.append(el)
    return result
elements = UnwrapElement(flatten(tolist(IN[0])))
selected = []
Icollection = List[ElementId]()
for e in elements:
	try:
		Icollection.Add(e.Id)
		selected.append(e)
	except:
		pass
DocumentManager.Instance.CurrentUIApplication.ActiveUIDocument.Selection.SetElementIds(Icollection)
OUT = selected
In your case, just plug it in the Select Model Elements or Select Model Element node and it will select and highlight your desired elements in Revit when you hit run… If you’d need to override elements, to give them a color, a slight modification needs to be done in the script, if you need that, just let me know.
Is there a work around to use this for linked elements?
@saju_autodesk …dont think its possible to override linked element as far i know, its only possible to hide them…but you could create a filter i think :wink:
try using “select element by id” node
thanks!
new to Python, how to i fix this warning?
That code was designed to work for IronPython2.7, but you’re running CPython3
Anyways, Synthesize toolkit is now switching to C#
Just search for SelectInRevit and you will find this node:
It will do the job
