Hi all, I’m pulling together a load of quick little scripts to throw into a custom extension for my users to quickly turn off all the annoying Visibility/Graphics issues (Reference planes, scope boxes, survey points etc).
However, when I try to use the same approach to create a script that turns off all RVT links, it behaves odd. Rather than toggling the visibility checkbox in V/G, it hides the links as it would if you were to right click > Hide in View. The V/G checkboxes are still checked, but the links are hidden. You can imagine the issues this would cause!
Could someone please take a look at my script and perhaps suggest a better approach?
Note that this does work with other categories, such as Survey Point and Grids, in as much as it toggles the V/G checkbox.
Where do you see a VG checkbox for links? Note that the links tab is inaccessible via the API and as such can’t be manually toggled.
A better solution here is likely to close / open the workset which the link is on (assuming you follow the best practice of one workset per link, one link per workset).
I didn’t realise that this was inaccessible, that may explain my issue!
I will look into the Workset solution as that would work better, providing I can be a good BIM co-ordinator and get all my studios to work to best practice!
It’s also possible to automate moving the links onto new worksets, where the workset name is created by putting X_ in front of the link name… users might mis-behave, but you can help them get back on track by building such tools.
For links, don’t hide the categoy.
Instead, hide the RevitLinkTypes with a hide element node.
You found one of the many peculiarities of the Revit API.
Thanks @Alban_de_Chasteigner, apologies I’m still quite new to my Dynamo journey, how would I go about changing my script to allow for this?
I’m guessing I can’t use the View.SetCategoryOverrides node to handle elements, but I can’t see a native Hide Elements Node. Do I need a certain package, or am I searching for the wrong thing?
You need to feed a document into the proceeding node - the red line on the input indicates it is missing an input and doesn’t have a default value to use instead.
