I’m trying to create a script that will hide all lines in a project with a certain name. I was following this post, but I can’t seem to get the same results. I can filter our my lines correctly, I just can’t seem to hide them. I seem to be getting string errors. Does anyone have any idea how to fix this?
Try setting the lacing on the View.HideElements node to Longest, and set the List@Level of input “Element” to L3. That might do the trick.
That seemed to give me more errors
Try flattening your list of lines.
That did it! It was that simple. Thanks guys
Setting your ListLevel to 3 is the same as leaving the list as it is. Level 3 is the outer most list, which is what the node would be looking at by default. You could just set the ListLevel to 1 and leave the lacing shortest. That should also work.
Interesting, I guess I thought of that backwards then. I always thought L3 was the innermost level. Thanks!
It does seem a little backwards at first, but it actually makes sense when you start using really deep lists. If you look at a node preview it actually tells you the list levels at the bottom. Each level lines up with the indent of its list/item.
