Hide/Unhide Detail Line via Style Name
Recently @c.poupin was a huge help with hide/unhide text script as seen below:
Hide/Unhide Text via Type Name:
clr.AddReference("RevitAPI")
import System
ueWrapper = None
wrappers = clr.GetClrType(Revit.Elements.ElementWrapper).GetMethods()
for w in wrappers:
	if w.ToString().startswith("Revit.Elements.UnknownElement"):
		ueWrapper = w
		break
def hideElements(textNotes):
	for i in textNotes:
		v = doc.GetElement(i.OwnerViewId)
		if not i.IsHidden(v) and i.CanBeHidden(v):
			v.HideElements(List[ElementId]([i.Id]))
def unHideElements(textNotes):
	for i in textNotes:
		if i.IsHidden(v):
			v.UnhideElements(List[ElementId]([i.Id]))
nameType = IN[0]
hideBool =  IN[1]
#filter constuction
pvp = ParameterValueProvider(ElementId(BuiltInParameter.SYMBOL_NAME_PARAM))
evaluator = FilterStringEquals()
rule = FilterStringRule(pvp, evaluator, nameType, True)
filter = ElementParameterFilter(rule)
textNotes = FilteredElementCollector(doc).OfClass(TextNote).WherePasses(filter).ToElements()
if hideBool:
#by pass the out Wrapper for Dynamo 2.0.4
textNotesUnwrap = [ueWrapper.Invoke(None, (txtN, False)) for txtN in textNotes ]
OUT = textNotesUnwrap
Could this be adapted to hide/unhide Detail Line via Style Name?
Thanks.
Yes it can be with modification:
import System
def hideElements(elem):
	res = []
	for i in elem:
			res.append(doc.GetElement(i.Id))
	return res
def unHideElements(elem):
	res = []
	for i in elem:
		if i.IsHidden(v):
	return res
line_style_Name = IN[0]
hideBool =  IN[1]
#filter constuction
fec_lines = FilteredElementCollector(doc).OfCategory(BuiltInCategory.OST_Lines).ToElements().FindAll(lambda x : Element.Name.GetValue(x)  == "Detail Lines")
lines = [x for x in fec_lines if x.LineStyle.Name == line_style_Name]
if hideBool:
	result = hideElements(lines)
	result = unHideElements(lines)
OUT = result
