I want to control the grid bubbles via Dynamo in Revit.
When I watch the Object Members of the Grids i can see the function,
but I can’t figure out how to run this method.
Can someone help me out.
In that case check revit api class Autodesk.Revit.DB.DatumPlane.
DatumPlane.HideBubble() – Hides bubble in the specified view
I found that too.
See also the Object Members in the first screenshot.
But i want to know how to set up a script with that api class.
Do you need code for rvt 2016?
yes
This code controls “ticking” stuff:
http://paste.ofcode.org/TzUV8PDdtyRtC3zCSKSeqJ
@Tomasz_Puchala
thanks for taking over this issue was busy bit.
@thurevit3 Kindly mark the post as solved. Thanks
Attached is a script that will turn on/off grid heads based on the intersection of a detail line/spline drawn through the grids. The purpose of this is to determine whether the user intends to turn off End0 or End 1 of the Grid (because the end nearest the bottom of the page might not be consistently 0 or 1…).
Grid Head Changer.dyn (18.3 KB)
Hi, I can’t seem to get this script to work (link does not work anymore). Also, how can i modify script to turn GridBubbles ON. Thanks
from RevitServices.Persistence import *
clr.AddReference("RevitAPI")
app = uiapp.Application
a = UnwrapElement(IN[0])
v = UnwrapElement(IN[1])
for i in a:
i.HideBubbleInView(DatumEnds.End1,v)
i.ShowBubbleInView(DatumEnds.End0,v)
#i.HideBubble(b)
doc.Regenerate()
OUT = 0
Ah… I’m using Revit 2015. I assume api is different?
This script is created with Dynamo 1.2 and the Revit 2017 api.
The node TB_Show-Hide is actually the Python script.
The .dyn file is attached
Toggle Grid Bubbles.dyn (11.6 KB)
Thanks for quick reply. I can only use Dynamo 1.0 and the project is in 2015.How can I change the script to work for 2015? Any advice would be great. Thanks
I don’t think you can, because this was a new feature of Revit API 2016. Sorry about that.
Those methods only work in 2016 and newer. The only way to do it pre-2016 was manually via the UI.
Thanks for the info guys
Thank you for sharing. It works fine for me.
Sorry for replying in an old thread, but I recently ran into this problem and tried this Node.
I downloaded the packeges and got rid of all warnings, and the node looks exactly like in your screenshot. But nothing happends to my grid-bubbles when I run the node. Am I missing something?
