Hey everyone!
I will really appreciate your help. I have a model with multiple plan views and I would like to hide a specific detail group in many views at the same time. I am using the archilab Views.HideElements in order to hide the detail group in a View Set. The output I am getting from the archilab node is false and no detail group is hidden.
Thanks in advance for any help you can provide!
you can hide it this way, BUT…
In general i would recommend to do it via a view-filter implemented in a view-template…
or even specify your view by the topic, that is implemented in the design representation (2D-Components)
KR
Andreas
Hi, @nitsanBCACP.
Made with Python, simple to hide/show attached groups with ShowAttachedDetailGroups from Revit API:
Show_attached_DetailGroup_.dyn (73.7 KB)
Fell free to ask for any changes.
Thank you @Draxl_Andreas and @Vladimir for your help. It is very appreciated!
In this specific case as I have many views that share the same view template, I would not want to assign new view template to some of the view due to a specific filter.
Also, the detail groups I would like to hide are not attached to any model group.
At least, after consulting a colleague of mine, I understood why the script I have made didn’t bring the desired result. Actually a detail group is not an “element” and that is the reason why they weren’t hidden. I have to “extract” all the members inside the desired detail group and place them in the “elements” input of the Views.HideElements node. ![]()
So, you see Detail Group unchecked in this window?
