Elements not hiding
Hide elements node is not working when I try to hide certain sections in a view. I even tried just inputting just raw views like seen here with no other nodes in the way yet it still doesn’t work
You need to hide the section markers, not the views.
That said I’d rather control that with filters in the view template in Revit IF possible.
I have 6 equal views. 2-6 are dependent on View 1.
When I create the dependent views it shows All sections in all views on top of each other. If I use templates I can either see all of them at once or none.
I want view one to have section 1 View 2 section 2 ect. Right now I either see all sections in all views or have to manually ho hide Section’s 2-6 from view 1 ect.
Could be done with dynamo but if there is a revit way it would be way better
Actually this seams inefficient, I will ask manager to change the project structure so we can use templates. Thank you.
