someone know how to change from imperial unit to metric unit in Vasari 3 beta?
thanks a lot:)
Manage Tab>Project Units and then just change whichever units you want. The content in the file will still be imperial just FYI.
thank you Lilli, but im doing the building performance analysis certificate. so i need to use the model that its already arrive from the certificate program. can you give me more details about how do i do it(from the manage tap)?
The easiest way is to start with a metric template from the getting started page. You can also change the units under the manage tab.
