Help with structure of a variable
I have a python script that i am working on to help with Revit Library management. The script currently iterates through a list of families and retrieves the category of the family. Everything works as expected until it gets to the variable obj_st, at which point i get the error message that the “Category with name BuiltInCategory.OST_Casework not found” but if was to type that in manually it would be fine.
How can i take the output of my OST variable and use it elsewhere?
you can also get BuiltInCategory like so:
bic = System.Enum.ToObject(BuiltInCategory,category.Id)
Maybe it will be more reliable then converting strings.
Perfect, Thank You!!
I can now get a list conataining the category of each family, but i’m getting stuck on the next step.
My variable “OST” returns the built-in category for each family, then “OST_sc” should return the Subcategories contained within each category. in my Watch node it shows each as “Autodesk.Revit.DB.Category” so i looked up the Revit API docs and tried some of the methods mentioned there like .Id or .Name but i get a message saying that these items are CategoryNameMap Class. How do i take these Subcategories and get properties like their name or Id?
CategoryNameMap is an iterator:
https://www.revitapidocs.com/2015/d452bf69-eef2-2d6c-1e8d-cc059c0fe513.htm
so you can loop through it’s elements:
cat = UnwrapElement(IN[0])
sc = cat.SubCategories
names = []
for c in sc:
	names.append(c.Name)
OUT = names
obraz
