FilterbyCategoryname doesnt work as expected
I am using a python script made by @Kulkul to get the OST Category name for Titleblocks.
See: How get OST (Built-In Name) of element - #6 by Kulkul
When i use the output of this node as input for Filter by category name, it doesnt work. I get an empty list, but when i use the drop down Categories node it works as expected.
I am supposed to be able to enter the OST name right?
The desired output but with a dropdown node:
Using the OST name and getting empty lists:
I tried flattening the list but that gives the same result.
The Python script:
Why do you think you need the Built-in category (OST) name and not just the common name (Title Blocks)? Can you not just use a String or Code Block and type in Title Blocks and be done?
Well, this is awkward…
Cant believe i didnt try that first.
I ran into this problem with multicategory tags needing the OST name and therefor I figured i had to input the OST name for titleblocks aswell.
Thanks for your help :slight_smile:
