i have script that works very well. With the lookup table i come until here! so how can i get the OST_ values. I`ve seen older post where they combine Category.Id too… is there a oneliner ?
#Template
#DraxlA
#19.07.2023
import sys
clr.AddReference('RevitAPI')
clr.AddReference('System')
#functions
def tolist(x):
if hasattr(x,'__iter__'): return x
else: return [x]
elements = UnwrapElement(tolist(IN[0]))
output = []
for e in elements:
output.append(e.Category.GetBuiltInCategory.ToString())
OUT = output
