Help: StructuralFraming.Beam By Curve
I’m a beginner and need help with a polygon beam system. I’m trying to create a polygon with an adjustable number of segments using a slider. I’ve attempted to use StructuralFraming.Beam By Curve with system curves, but it returns a null result.
Thank you so much
Hi @thaibao95arcEP58P ,
I think the node requires a curve not a polycurve, you could try geometry explode node and than feed that it. You may also need to play with your levels.
CheersKS
Thank you so much, Its really work!
