I am trying to make a copy to model a window on a wall and modeling, I have the doubt on how to obtain the “Curve” of the wall to turn it into a beam with the node Structure structural Beam By Curve. Thank you
Hi @jamess166
Remove polycurve connection and connect “Element.GetLocation” to it. The error says it all “Polycurve is not iterable”. It is expecting curve right now your connecting polycurve to it.
Use Curve.Approximatewith Arc and LineSegments node after Element.GetLocation to convert line to curve.
I have another doubt, the line comes out at the base of the wall, as I do to project it on the top, thanks
@jamess166 You could also use OOTB nodes.
you are a crack, thank you very much
Sorry for the inconvenience, but I am trying to make a Join Geometry to the beam with the wall, however for some reason it does not work, I have tried the scrip in a separate file selecting the beams and the walls and it works for me, I hope some recommendations. Thank you
please start a new topic.
