I need help trying to create a Python script that will select all of the titleBlockFamilyTypes in my current Revit model so that the user may select the titleblock to be used in data-shapes drop down menu. The titleblock family type will then replace the “Select TitleBlock for Sheets” node used to create sheets in Revit. Thank you in advance for your help.
# Import RevitAPI
clr.AddReference('RevitAPI')
from Revit.Elements import *
titleblock_collector = FilteredElementCollector(doc) \
.OfCategory(BuiltInCategory.OST_TitleBlocks)
titleblock_Families =
OUT = titleblock_Families
