Title Block Family and Type
Hi everyone
I have a script in which I collect all the Title Block Types in the project, but I can’t seem to figure out how to get the type name
This is my code:
#import RevitAPI
clr.AddReference('RevitAPI')
from Autodesk.Revit.DB import FilteredElementCollector, BuiltInCategory, Element, FamilySymbol
doc = __revit__.ActiveUIDocument.Document
titleBlocks = FilteredElementCollector(doc).WhereElementIsElementType().OfCategory(BuiltInCategory.OST_TitleBlocks).ToElements()
The Family Name can be easily called with the ‘FamilyName’-attribute, but how do I get the Type Name, I have to be missing something…
Any help is welcome!
@PieterL_TM ,
i copied the template Python primier - it works!
import sys
import System
clr.AddReference('System')
OUT = titleBlocks
grafik
KR
Andreas
My bad, I didn’t specify that I was writing this outside of dynamo. I want the Type Name as a string in Python.
If you’re already dealing with the Types then the Name property should be the type name or you can always look up the Type Name parameter value.
Yes the lookup worked, I don’t understand why just calling the Name doen’t work though.
