Hello Im trying to make a code that makes floor out of a model line or a detail line
the first image is what happens when I make the model lines into a multi floor the second image is of a the code and there is no errors when I run
Hello, look at the node in the dictionary it’s a good way to start with the illustrated example
Sincerely
christian.stan
thank you christian.stan it did help its counting the lines being separated instead of being in loop
Here is an other example if you are looking for that
more visible
Sincerely
christian.stan
thank you so much for the help i have one question how did you get multi level to work
you create a list of levels and you pay attention to list management
Sincerely
christian.stan
