Group Parallel Lines by Direction and Distance
I used the Python Script by @viktor_kuzev from the topic (Group closest parallel lines which are equal in length) and it worked out well for majority of the lines.
But a few lines [orange and violet] although parallel (to the eye) are not being grouped appropriately.
I tried changing the code to check if reversing the direction would work but it didn’t.
What would you suggest I should try next?
Test_Revit2019.rvt (2.2 MB)
hello @AmolShah
try this
clr.AddReference('RevitAPI')
import sys
sys.path.append(r'C:\Program Files (x86)\IronPython 2.7\Lib')
import random
def nearCond(lstelemb, elema):
	check = False
	midpta = elema.Location.Curve.Evaluate(0.5, True)
	for elemb in lstelemb:
		midptb = elemb.Location.Curve.Evaluate(0.5, True)
		if midpta.DistanceTo(midptb) < margin:
			check = True
			break
	return check
def colorRamdom(elements, view):
	rvtcolor = Color(random.randint(0, 255), random.randint(0, 255), random.randint(0, 255))
	gSettings = OverrideGraphicSettings()
	gSettings.SetProjectionFillColor(rvtcolor)
	gSettings.SetProjectionLineColor(rvtcolor)
	gSettings.SetCutLineColor(rvtcolor)
	gSettings.SetCutFillColor(rvtcolor)
	for element in elements:
		view.SetElementOverrides(element.Id, gSettings)
margin = IN[0] #test at 0.5
collCond = FilteredElementCollector(doc, doc.ActiveView.Id).OfCategory(BuiltInCategory.OST_Conduit).WhereElementIsNotElementType().ToElements()
finalgroups = []
filterPassId = []
for conda in collCond:
	if conda.Id not in filterPassId:
		filterPassId.append(conda.Id)
		vecta = conda.Location.Curve.Direction
		templst = [conda]
		for condb in collCond:
			if conda.Id != condb.Id:
				vectb = condb.Location.Curve.Direction
				if vecta.IsAlmostEqualTo(vectb, 0.15) or vecta.IsAlmostEqualTo(vectb.Negate(), 0.15) :
					if nearCond(templst, condb):
						templst.append(condb)
						filterPassId.append(condb.Id)
		finalgroups.append(templst)
		colorRamdom(templst, doc.ActiveView)
OUT = finalgroups
you can delete the colorRamdom function if you don’t use it
Hi @c.poupin,
Thank you so much for taking time to help me solve this problem.
It works perfectly as intended on the file I shared.
However, it threw some unexpected results when I tested it on the other file shared below!
Test_Revit2019_2.rvt (2.4 MB)
corrected script
the margin is the max margin between conduits
#written by Cyril.P
import sys
import random
	global margin
	check = False
	curva = elema.Location.Curve
		curvb = elemb.Location.Curve
		if curvb.Project(midpta).Distance < margin:
			check = True
			break
	return check
def getConduitParallal(collCond, conda):
	outLst = []
	curva = conda.Location.Curve
	midptfun = lambda x : x.Location.Curve.Evaluate(0.5, True)
	midpta = midptfun(conda)
		if conda.Id != condb.Id :
				outLst.append(condb)
	if outLst:
		#sort element by distance
		outLst.sort(key = lambda x : curva.Project(midptfun(x)).Distance )
	return outLst
margin = IN[0] #max margin between conduits
finalgroups = []
filterPassId = []
		templst = [conda]
		elemsParall = getConduitParallal(collCond, conda)
		for condb in elemsParall:
OUT = finalgroups
Works like a charm.
Thank you :slight_smile:
