I found this topic Group Parallel Lines by Direction and Distance
But i want to group lines parallel to each other, and don’t care about the length, anyone there can help with that? ![]()
Hi @nichlas.aa.holm,
There is a Group Parallel Lines custom node in the Genius Loci package.
Hi @nichlas.aa.holm ,
You could also get the direction of the lines using the Line.Direction node. Then use those values as the keys in a List.GroupByKey node (together with the lines themself).
PS: It could be that rounding of those values is necessary.
It seem to work, but how does i round a vector?? ![]()
I tried that node, its don’t work. It just return “null”, without any error message.
You could use the Vector.AboutAxis node to measure your vectors against the X-Axis, revolving around the Z-axis. This should result in doubles from 0-360.
