Group multiple elements, parameters, and values using Python
I am trying to get/set the parameters (Comments, Mark) of multiple Revit elements. I can’t seem to make a group of [element, parameter, value] for the same.
def uwlist(input):
    result = input if isinstance(input, list) else [input]
    return UnwrapElement(result)
# Preparing input from dynamo to revit
elems = uwlist(IN[0])
params = uwlist(IN[1])
pValues = uwlist(IN[2])
outlist = []
for e in elems:
	for p, pv in zip(params, pValues):
		outlist.append([e,p,pv])
OUT = outlist
I think you are nesting your lists, is that what you want?
I’d presume you want them separately?
I’m not sure, but it might be that the use of a list created inside the first For Loop gives you the structure you are wanting?
Whether a list is created inside or outside the For Loop affects its behaviour.
Hope that helps,
Mark
Well, the problem here is the parameter values. Instead of doing transpose and flatten on the Parameter Values, I want to use them directly in Python.
def tolist(input):
    return result
def uwlist(input):
elements = uwlist(IN[0])
params = tolist(IN[1])
values = tolist(IN[2])
rParams = []
rValues = []
rElements = []
for e in elements:
	for p in params:
		rParams1 = e.LookupParameter(p)
		rParams.append(rParams1)
		rValues1 = rParams1.AsString()
		rValues.append(rValues1)
		rElements.append(e)
rParamsName = []
for p in rParams:
	rParamsName.append(p.Definition.Name)
for p,v in zip(rParams, values):
	p.Set(v)
OUT = rElements, rParamsName, rValues
try this?
def tolist(input):
    return result
def uwlist(input):
rParams = []
rValues = []
rElements = []
for i, e in enumerate(elements):
	for j, p in enumerate(params):
		rElements.append(e)
        rParams1.Set(values[j][i])
rParamsName = []
for p in rParams:
It’s only setting the parameter values of the last parameter.
I don’t know what you want to achieve, let others to help you maybe :slight_smile:
It worked. Just need to move this line of code rParams1.Set(values[j][i]) up so the parameter value is set as soon as the parameter is grabbed from API.
def tolist(input):
    return result
def uwlist(input):
rParams = []
rValues = []
rElements = []
		rElements.append(e)
rParamsName = []
for p in rParams:
so strange, the sequence should have no influence in here :face_with_monocle: they are in same loop, dont know why, but anyway happy you figured it out :slight_smile:
