New to Python - grid lines
I am trying to select an existing grid, get the start/end coordinates and then make more girds based on that. I have the following code and have tried others from online without success. This is my first attempt at writing something so please don’t judge.
from Autodesk.Revit import DB
from Autodesk.Revit import UI
from pyrevit import revit, UI
#Input from selection
crv = revit.uidoc.Selection.PickObject(UI.Selection.ObjectType.Element)
startpoints = []
for crv in curves:
	startpoints.Add(crv.StartPoint)
	print(startpoints)
OUT = startpoints
startpoints()
Hi @jstro and welcome
here an example
import sys
import System
#import Revit API
clr.AddReference('RevitAPI')
#import Revit APIUI namespace
from Autodesk.Revit.UI.Selection import *
#import net library
refE = uidoc.Selection.PickObject(ObjectType.Element)
elem = doc.GetElement(refE)
if isinstance(elem, DB.Grid):
	curveGrid = elem.Curve
	startPoint = curveGrid.GetEndPoint(0)
	# convert point to Prototype
	DS_StartPoint = startPoint.ToPoint()
	OUT = DS_StartPoint
you can find more information here
