Hi!
I have a simple script that gets the spaces in a Revit project and passes them to surfaces. Then with the Lunchbox Quad Grid by Face nod I manage to do a grid on them. But it only works for rectangular surfaces.
Is there a way to grid irregular surfaces with that node, or is there another node? Maybe split previously the spases with something.
I attach a photo of an example of spaces and how they get a grid. I had to separate the room in the middle into two regular spaces because otherwise it would crash.
You could use isocurve a to build a grid on your own and then turn the isocurves into surfaces, join them into U and V axis aligned polysurfaces, and use that to split your base surfaces into a sub-sections of the surface. This could have some issues with oddly shaped rooms but the ‘surface area’ in question should work.
But if I do a general grid, it would not divide the surfaces equally in them, but divide them according to the whole project.
Can you provide a sketch of your ideal grid segmentation?
I solved it by grouping the curves by extended parallel lines and appyling it to the surface as a grid and an intersection
It was the picture on the right
