hi,
similar like placing the grid extents outside the crop region, is that possible to place the tags(Room/Space) outside the crop region.
@c.poupin
Tag alignment based on Crop Region 1.3.0.dyn (27.6 KB)
hi,
@c.poupin
Hello
have you an example (screenshot result)?
Hello @dhilipseshan ,
try this variant
the script processes all roomtags in active View, the offset distance must be entered manually
clr.AddReference('RevitAPI')
from Autodesk.Revit.DB.Architecture import *
def moveTgtoCrop(boundLines, rtag):
ptTag = rtag.Location.Point
lstInter = []
for lineBound in boundLines:
interResult = lineBound.Project(ptTag)
lstInter.append(interResult)
lstInter.sort(key = lambda x : ptTag.DistanceTo(x.XYZPoint))
firsttInterResult = lstInter[0]
rtag.TagHeadPosition = firsttInterResult.XYZPoint
#move location to update TagHeadPosition
rtag.Location.Move(XYZ(0.001,0.001,0))
def getBoundLines(bbx, Zvalue, offsetCrop = 1):
lstPt = []
lstLine = []
lstPt.append(XYZ(bbx.Min.X, bbx.Min.Y, Zvalue))
lstPt.append(XYZ(bbx.Max.X, bbx.Min.Y, Zvalue))
lstPt.append(XYZ(bbx.Max.X, bbx.Max.Y, Zvalue))
lstPt.append(XYZ(bbx.Min.X, bbx.Max.Y, Zvalue))
for idx, pt in enumerate(lstPt):
if idx == 0:
lstLine.append(Line.CreateBound(lstPt[- 1], pt))
lstLine.append(Line.CreateBound(lstPt[idx - 1], pt))
polycuDS = DS.PolyCurve.ByJoinedCurves([x.ToProtoType() for x in lstLine])
polycuDS = polycuDS.Offset(offsetCrop)
rvtLines = [x.ToRevitType() for x in polycuDS.Explode()]
return rvtLines
offsetCrop = IN[0]
activView = doc.ActiveView
cropBox = activView.CropBox
viewRange = activView.GetViewRange()
cutOffset = viewRange.GetOffset(PlanViewPlane.CutPlane)
fecRoomTg = FilteredElementCollector(doc, activView.Id).OfCategory(BuiltInCategory.OST_RoomTags).ToElements()
boundLines = getBoundLines(cropBox, cutOffset, offsetCrop)
for rtag in fecRoomTg:
OUT = fecRoomTg
Hi @c.poupin ,
looks amazing.
This works perfect for top and bottom leaders.
I used same for space tag also.Tag based on crop region-python.dyn (8.2 KB)
for top and bottom leader comes straight
but in left and right it doesn’t coming straight as shown in sample image.
ok thank you so much for your precious time.
