Hello Y’all, I have the following script
# Copyright(c) 2017, Dimitar Venkov
# @5devene, dimitar.ven@gmail.com
# www.badmonkeys.net
clr.AddReference("RevitAPI")
from Autodesk.Revit.DB import RevitLinkInstance, FamilyInstance
def output1(x):
if len(x) == 1: return x[0]
else : return x
sel1 = uidoc.Selection
ot1 = Selection.ObjectType.Element
ot2 = Selection.ObjectType.PointOnElement
li_ref = sel1.PickObject(ot1, "Select a link instance first.")
link1 = doc.GetElement(li_ref.ElementId)
if isinstance(link1, RevitLinkInstance):
tf1 = link1.GetTotalTransform()
face_ref = sel1.PickObject(ot2, "Pick a face.")
linkDoc = link1.GetLinkDocument()
el1 = linkDoc.GetElement(face_ref.LinkedElementId)
face_ref2 = face_ref.CreateReferenceInLink()
sf0 = el1.GetGeometryObjectFromReference(face_ref2)
if isinstance(el1, FamilyInstance):
tf1 *= el1.GetTotalTransform()
sf1 = sf0.Convert(face_ref2, tf1.ToCoordinateSystem(True) )
for s in sf1:
s.Tags.AddTag("RevitFaceReference", face_ref)
OUT = output1(sf1), face_ref.GlobalPoint.ToPoint(True), link1
el1 = link1
sf0 = link1.GetGeometryObjectFromReference(face_ref)
sf1 = sf0.Convert(face_ref, tf1.ToCoordinateSystem(True))
(Thanks dimitar for the awesome script btw) which gets the transformation of a element and use it as the basis of operation to rotate my view orthogonally to the plan i select… But it doesn’t work with “system types”, like walltypes, ceilings, etc… cause they don’t have the method “GetTotalTransform”, which i’m guessing by now only apply to model in-place elements… I looked throught the revitapidocs.com in search of a similar method for walltypes, but i can’t seen to find one.
This is my first try messing around with the API, so any help is very helpful
