Hi all, I have created a python script using what I have with the node to code in Dynamo.
However, I keep getting the issue
File “”, line 22, in
NameError: name ‘Elements’ is not defined
How do I rectify the error? My code is as follows,
clr.AddReference(‘RevitAPI’)
clr.AddReference(‘RevitNodes’)
from Autodesk.DesignScript import Geometry
clr.AddReference(‘DSCoreNodes’)
import DSCore
from DSCore import *
elements = UnwrapElement(IN[0])
solidlst =
for elementsolids in elements:
solids = Elements.Element.Solids(elementsolids);
solidlst.append(solids)
for sldele in solidlst:
for ele in sldele:
solid = Solid.ByUnion(solidlst);
plysrf = PolySurface.BySolid(solid);
srf = PolySurface.Surfaces(plysrf);
OUT = srf
Thank you!
