Getting sharedparameter GUID, how?
i can call my Parameter, but how can i get his GUID?
clr.AddReference('System')
clr.AddReference("System.IO")
from System import *
from System.Reflection import *
from System.IO import *
#Use elemIds = List[ElementId](ids) for ICollection(ElementId)
#Import the Revit Services
app = uiapp.Application
#Import the Revit Nodes
# Import geometry conversion extension methods
#Import the Revit API
clr.AddReference("RevitAPI")
element = UnwrapElement(IN[0])
look = element.LookupParameter('HauptmaterialitaetElement')
OUT = look
Try this (not at my desk so I can’t confirm):
paramGUID = look.GuidValue
2022-06-20_14h36_32
@jacob.small ,
i can`t catch it.
Can you confirm it’s a shared parameter? IsShared Property
@jacob.small ,
how do i do that, it is a boolean as answear?
shared = look.IsShared
guid = look.GuidValue
Was the answer in this case true or false? If false you wouldn’t have a GUID as it isn’t a shared parameter.
When i call just this it is true! @jacob.small when i ad GuidValue … it is not callable
def GetParamGUID(param):
	if hasattr(param, "GuidValue"): return param.GuidValue.ToString()
	else: return None
guid = GetParamGUID(look)
OUT = guid,shared
value is Null :confused:
2022-06-20_15h49_22
It works for my one… Something about your parameter perhaps?
@Mark.Ackerley
I need the sharedParameterGUID not the unique Revit ID!
Apologies, I’m a little confused… Isn’t that this? :slight_smile:
Thank you so just call it with GUID!
