I am passing a parameter definition (that I know is shared) into a node and trying to return the GUID from the parameter (not from External Definition).
I keep getting Null returned. Here is my code for the Get GUID node, can you please help?
Import RevitAPI
clr.AddReference(“RevitAPI”)
Import DocumentManager and TransactionManager
Import ToDSType(bool) extension method
import System
from System import Guid
app = DocumentManager.Instance.CurrentUIApplication.Application
#The input to this node will be stored in the IN[0] variable.
elementz = IN[0]
parg =
for i in elementz:
parg.append(i.GUID.ToString())
#Assign your output to the OUT variable
OUT = parg
