I have been trying out if its possible to get a parameter value of multiple specific wall types that I filtered from the element list. No luck so far, so I’m looking to get any advice if this actually works for multiple elements.
Any help is much appreciated. Happy to hear any recommendation that would simplify the script.
This workflow you have there is almost correct, but you are trying to get the “Area” parameter, which is contained in the instances, not the types. For that, you need to connect “All Elements Of Category” to “List.FilterByBoolMask”.
There are other parameter contained on the Types. If you switch for any of them, you’ll get their values.
Refer to your other topic, which has a solution, found here: Getting the Area of a Wall type - #4 by sovitek
