I’m trying to extract only the interior walls from the Wall category but only in a SOLID output.
here is the script that I have below.
I need to have the same outcome as Furniture line (above Wall) - which is in Solid.
You want to filter the wall elements, not the parameter values. Then after filtering get the solids of the included walls. Graph was a bit tight but did my beat to markup the steps in blue, then purple.
