Hi.
I want to get a solid of the interior the building. If I go through the rooms, there are gaps in between. How can I fill them? I came up with a method like this:
In Python, temporarily delete the interior walls and replace the location with a room separator. But I can’t find how to write this.
you could try grap all your interior walls solid, probably with geometry + from clockwork so you can get without insert etc…and then your rooms, and solid union…or get center boundery from rooms and union maybe ![]()
If you use the centerline of the rooms when pulling the geometry to remove the ‘wall’ gaps, however I am not sure how well that will work for roofs and floors though - what’s the end use? There may be a better process to get what you’re after.
yeah
guess for floors and roof, it will depends on the rooms height, in that example here, so indeed there could be a better way…depends
Hi! Arhilab’s RoomBoundaries works here:
It takes Core boundaries by default. You can extrude them after with extra values to eliminate horizontal gaps.
It would be better for my scenario to get the rooms separately. I tried the first method I thought of for this and I succeeded! I can’t wait to share it with you.
clr.AddReference('RevitAPI')
# Rooms
all_room_list = FilteredElementCollector(doc).OfCategory(BuiltInCategory.OST_Rooms).WhereElementIsNotElementType().ToElements()
# To access the view from the name to place the room separator.
views = {}
views_all = FilteredElementCollector(doc).OfClass(View)
for view in views_all:
views[view.Name] = view
# Interior walls to be placed room separator from locations. Will be temporarily deleted
all_wall_list = FilteredElementCollector(doc).OfCategory(BuiltInCategory.OST_Walls).WhereElementIsNotElementType().ToElements()
interior_wall_list = [wall for wall in all_wall_list if "22_WA" in wall.Name]
# Floors to be temporarily deleted
all_floor_list = FilteredElementCollector(doc).OfCategory(BuiltInCategory.OST_Floors).WhereElementIsNotElementType().ToElements()
op = []
# Start the temporary process
trans = SubTransaction(doc)
trans.Start()
# Place a room separator at the location of the interior walls and delete the walls.
for wall in interior_wall_list:
wall_level_name = doc.GetElement(wall.LevelId).Name
view = views[wall_level_name]
wall_location = wall.Location.Curve
curvearray = CurveArray()
curvearray.Append(wall_location)
origin = wall_location.ToProtoType().PointAtParameter(0.5)
xyz_origin = XYZ(origin.X,origin.Y,origin.Z)
normal = XYZ.BasisZ
plane = Plane.CreateByNormalAndOrigin(normal,xyz_origin)
sketch_plane = SketchPlane.Create(doc,plane)
separator = doc.Create.NewRoomBoundaryLines(sketch_plane, curvearray, view)
doc.Delete(wall.Id)
# Delete Floors
for floor in all_floor_list:
doc.Delete(floor.Id)
# To process the deleted walls and floors into the document for updating the rooms.
doc.Regenerate()
# Rooms and their geometries redefined with room seperators without internal wall and floor boundaries
geo_options = Options()
for room in all_room_list:
room_geometry = list(room.Geometry[geo_options])[0].ToProtoType()
op.append([room,room_geometry])
# Restore deleted floors and walls
trans.RollBack()
OUT = op
