Find that path on your local disc - if it isn’t there, than this method won’t work because the file doesn’t exist. Note that seeing the file in desktop connector is not the same as on the disc - those are really just references to another location (which isn’t really clear in terms of what that is). A better solution might be to look at the ‘file size on open’ in the journal for the session.
