BIM 360 File Paths
Hi all,
does anyone know if there is a way to get the actual path of a BIM 360 File?
I want to use a node to link several files from the BIM 360 Cloud, but apparently the path doesn’t work.
I’m using something like :
“BIM 360://working_folder/file.rvt”
Use the CentralPath node from the Springs Package.
Thanks Sean,
but that node returns the same BIM 360 path (“BIM 360://working_folder/file.rvt”) that doesn’t work inside Dynamo
Have run into this problem as well. Did you end up finding a solution @sweapon?
Same issue here !
Did you find a solution?
You need to go through the BIM 360 folder in file explorer that is added via the desktop connector.
