Convert planarface to DS face
Hi!
I got planar faces where I extracted from solid using solid.Faces
But how can I convert them to DS faces?
I tried GetSurface() but it returns plane :frowning:
thanks!
@newshunhk ,
Can you share the code? which Dynamo and Revit do you use?
Just trying to find all the surfaces of a stair:
import sys
import System
clr.AddReference('RevitAPI')
def get_VolumeSolid(elem):
    opt = Options()
    solid = []
    geoSet = elem.get_Geometry(opt)
    for geo in geoSet:
        if isinstance(geo, Solid):
        	for f in geo.Faces:
				solid.append(f.ToProtoType())
        elif isinstance(geo, GeometryInstance):
            geoi = geo.GetInstanceGeometry()
            for g in geoi:
                if isinstance(g, Solid):
					for f in g.Faces:
    geoSet.Dispose()
    opt.Dispose()
    return solid
def toList(x):
    if isinstance(x, list):
        return x
    elif hasattr(x, "GetType") and x.GetType().GetInterface("IEnumerable") is not None:
        return x
    else :
        return [x]
lstelems = toList(UnwrapElement(IN[0]))
OUT = [get_VolumeSolid(e) for e in lstelems]
@newshunhk ,
you want access via python ?
I don’t use element.geometry because it will halt my revit or fail to convert if there is some spiral or bad drawn sketch based stairs.
@newshunhk ,
oh… hmmm :confused:
# This node has been made by Modelical
# www.modelical.com
def flatten(x):
    result = []
    for el in x:
        if hasattr(el, "__iter__") and not isinstance(el, basestring):
            result.extend(flatten(el))
            result.append(el)
    return result
def toList(input):
	"""Return iterable if available, a list of 1 otherwise"""
	if hasattr(input, "__iter__") and not isinstance(input, basestring):
		return input
		return [input]
stairs = toList(IN[0])
stairsSrfs = []
stairAreas = []
for st in stairs:
	solids = st.Geometry()
	tempPSrf = []
	for s in solids:
		tempPSrf.append(PolySurface.Surfaces(PolySurface.BySolid(s)))
	stairsSrfs.append(flatten(tempPSrf))
for sSrfs in stairsSrfs:
	tempSrf = []
	for srf in sSrfs:
		if Surface.NormalAtParameter(srf, 0, 0).Z == 1:
			tempSrf.append(srf.Area)
	stairAreas.append(sum(map(float,tempSrf)))
OUT = stairAreas
the script from Modelical is no use, it uses dynamo element.geometry.
Hi @newshunhk,
You have to import the RevitNodes.dll and use geometryconversion to use ToProtoType().
# Adds ToProtoType, ToRevitType geometry conversion extension methods to objects
    opt = Options()
    solid = []
    for geo in geoSet:
        	for f in geo.Faces:
            for g in geoi:
					for f in g.Faces:
    geoSet.Dispose()
    opt.Dispose()
    return solid
def toList(x):
        return x
    elif hasattr(x, 'GetType') and x.GetType().GetInterface('IEnumerable') is not None:
        return x
    else :
        return [x]
oh!!! yes I forgot to import
thank you !!! :slight_smile:
