Element.Faces failed - “PolyCurves may be branching”. Changing geometry working range not working
Hi, when I used Element.Faces to get the element faces there was an error called Element.get_Faces operation failed. PolyCurves may be branching. I tried to change the geometry working range from small to extra large as suggested by other posts but all of the four ranges could not work.
I wrote some python scripts to capture the error elements as below.
import sys
elements = IN[0]
faces = []
errors = []
for element in elements:
    try:
        faces.append(element.Faces)
    except:
        errors.append(element)
OUT =  faces, errors
It showed that there are three error elements as below. But they look so normal…
Any solutions to this problem? Thanks!
Revit model and dynamo file:
dynamo.dyn (18.1 KB)
help…
Hi Howie…it works for me…try to set you column type to another type and run, set it back again and it works…very strange…
Thanks @sovitek !
Same to me…strange…
